I have a '41 9N with a 6V single wire generator system having battery charging problems. I decided to rewiring the system and learned the regular start switch was by-passed and a solenoid added inside the dash along with a separate push button switch outside.
I have replaced the ammeter, generator, push button switch, cutout switch, resistor block and wiring harness.
I kept the solenoid connected to the battery and to the starter cables. The ammeter is also connected to the BAT side of the solenoid and the start SW is connected to one of the solenoid posts.
The 6 Volt GEN is connected to the cutout SW and continues up to the resistor block from the BAT side of the cutout.
I continue to have a problem with charging a one yr. old battery.
I suspect the solenoid is shorted or maybe should not be in the system to begin with. Charging has never been a strong point with this arrangement.
If this is correct I will rebuild the old starter SW to get back to pure 9N design.
Should I replace the external solenoid and start SW?
Any comment?
Thanks
Gerb
Any comment?
Thanks
Gerb
