Super 77 N H Baler Shaft gearbox
I finally got pic. of the shaft on the super 77 baler that someone {Bill} wanted to see. He did not build one. He found one. the shaft & gear box off another super 77 that A man had salvage in A junk yard. Not too many around.
Will sent pic. of it.
Hope this will help.
Hammer Man
You might tell the guy that the pickup is the weak point on those balers. The chain carrying the pick up teeth has been known to jump off the track. Also, the small chain on the outside of the baler on the pickup chain sometimes jumps off due to the pickup bouncing up and down on uneven ground. I solved that problem by welding a crudely cut out flange on top of the idler pulley.
KEH
