Herman Donny
New User
I have a. White 6125 with the funk 18 speed powershift worrks well in speeds 1-9 but has lost all speeds from 10-18" just freewheels to a stop. Can hear the trans shifting but won"t go .no load on tractor. Tach and ground speed indicator operate normally. Error code reads e01, which means trans overload. What could be the problem? Occasionally will operate normally, so the problem must be electrical or valve related . What do you think?
Thanks don.
Check your range solenoids underneath the cab on the right side of the tractor. More than likely one of those is bad or a wire came off. I can"t rightly tell you which on the upper range is but that is what happened to our 6215.
I switched some solenoid s from one position to another and it is working well now, I suspect a poor connection or a weak solenoid, we,ll see how long it goes like this now ,thanks ,don.
