charlespretzer Ks.
Bought a Farmall Cub last week. It hadn't ran for a year, ran alittle rough, smoked alittle. tried Seafoam,It smoked alot then quit smoking & ended up running real smooth.Maybe I'll put it in everything!
(quoted from post at 00:22:10 08/14/13) Bought a Farmall Cub last week. It hadn't ran for a year, ran alittle rough, smoked alittle. tried Seafoam,It smoked alot then quit smoking & ended up running real smooth.Maybe I'll put it in everything!
(quoted from post at 05:16:40 08/14/13) No chem major needed.Just use 1/3 of each chemical and mix in a bottle.Seafoam costs about 80 buck a gallon.Mineral oil can be found in drug stores.I paid 2.50 for a quart of water free isopropyl alcohol.I keep acetone and naptha on hand.Fuel injector cleaner is a mix of alcohol and kerosene.
(quoted from post at 16:22:10 08/13/13) Bought a Farmall Cub last week. It hadn't ran for a year, ran alittle rough, smoked alittle. tried Seafoam,It smoked alot then quit smoking & ended up running real smooth.Maybe I'll put it in everything!
(quoted from post at 05:08:49 08/14/13) Ever thought just running that stiff dry engine that had gummed up combustion chambers, stuck rings and old gasoline in the fuel system. Ever consider that the engine would have warmed up without the snake oil and burned off the crude without the snake oil.
Here you are advertising snake oil and not even being paid.
(quoted from post at 02:48:16 08/15/13) Truth hurts a bit.Plenty of posters on here have extensive knowledge of many subjects.It stings to know you are paying 80 bucks a gallon for common chemicals.You could make 3 gallons of seafoam for 30 bucks buying the the chemicals at retail in a hardware store.
(quoted from post at 09:21:31 08/14/13) I thought Coleman fuel was white gas. Is white gas the same as naphtha?
(quoted from post at 09:21:31 08/14/13)Also thought Seafoam was baby oil and alcohol, not mineral oil.
Not being ugly, just want to know.
