older new holland 488 haybine
Anonymous-0
asking for a friend when hes running the haybine the wobble bolt keeps breaking. just changed the cylinder and it started happening could this be the problem or maybe something else. any suggestions would be helpful. thank you!!!
It could just be a tough crop. The wobble bolt should be inside a rubber bushing that helps take some of the shock. We always replace the bolt and the rubber bushing as a unit. Try leaving a higher stubble.
