John M
- Location
- Nunyafn business
We do use it a shows sometimes when my friends
disabled Dad goes with us so its tractor related.
Buddy of mine has I think a 88 Club Car with the
Kawasaki engine. Guy he bought it from put a reman
engine it early last year, and an hour meter per
the warranty disclosure in the paperwork. Time has
expired on it, but the engine only has 16 or 17
hours on, and pretty easy hours at that, as I said
they mainly use it at shows. He has opened it a
cople of times I know of on the road. Now what its
doing is you can run it fine for a little bit,
like 15 minutes or so, then stop, engine shuts
down and sometimes, but not always, it will lock
the engine up. You can put a strap wrench, which
he keeps on the cart, and turn the engine
backwards a couple of turns and then it will go
again until it locks up again. What I know hes
done so far is to take both belts off when it
locks up to see if either the starter/genny is
locked or the clutch locked up causing the belt to
bind to the rear end, he says neither was the
case. He hasnt done anything to it in a couple of
months, but thinks he may need it in a couple of
weeks if his Dad can get down here for a show.
Anybody by chance run across this before?
