Case LA starter upgrade?
Anonymous-0
Have a friend with a LA puller that needs a better starter? is there an aftermarket starter out there that has more cranking power? I believe this one slips in to a round hole and is held by a set bolt?
Upping the voltage to the starter may do the trick.
An electrical shop may also be able to rewind it and get more torque out of it.
In stock form, that"s a 400 cubic inch engine,-
100 cubic inch"s per cylinder. if any mod"s have
been done, to up compression, it"s going to
require an extra powerful starter !
Suggest asking on the tractor pulling form as I have seen many different starter types on large cube high compression engines.
