I bought a gravity wagon and running gear at a sale 8-10 years ago. The gravity box was a real nice 400 Bushel Parker one. The running gear was a 10 ton Electric gear. It was not heavy enough for the gravity box. So I bought a 14 ton Meyers wagon for the gravity box. The Electric 10 ton wagon just set in the weeds since then. I kept in in the back of my mind for some kind of use.
I got it out last week and cleaned it up. I had to rebuild the telescoping tongue as it was messed up. I replaced all the bearings and seals. Than fresh coat of paint and two new tires and the wagon was done.
While cleaning up the wagon I found the name plate. I never knew what the full company name was for Electric wagons. There were a lot of them around here years ago. The name plate read: Firestone Electric Wheel Company, Quincy, IL. Never new Firestone owned them. Looked on the Internet and it seems that Titan Tire now owns it. Just found that interesting.
The bale mover/rack is a full 10 ft. wide and 24 ft long. I had to lengthen the coupling pole to get the wheels where I wanted them. The main tubes are 4 x 8 x 1/4 walled square tubing. The cross tubes are 3 x 4 x 5/16 walled tubing. I placed a lot of gussets at angles to brace everything and to keep the tubes supported.
I have a factory built one and the tubes are breaking all of the time. They are lighter metal and it has fewer gussets.
So the final mover will hold 8 bales on the bottom and I will more than likely stack 3 more on top. We have the quick hitches for the chopper boxes and one of them will fit this wagon tongue. So it should work real nice for bring bales in.
I think it turned out fairly well.
