redmcc
New User
Power shift for 3 speeds forward reverse is loose and just moves back and forth doesn't do any thing. 4 gears forward work just not the power shift. Any ideas?
Not enough info. Could be a torque limiter plate, but we don't know the sn# to determin this posibility, or how the hydraulice are working, or if.
Post down on the Case forum, with more info. so we can get you headed in the correct direct direction. You probably will need someone to do a complete flow and pressure check of the hydraulic system to determin your problem.
Loren, the Acg.
