1.5 inch square toolbar clamps
I just purchased a 3 point toolbar for my tractor and was hoping to use Farmall feet on it but it"s 1.5 inch square instead of 1 3/8. Does anyone know of clamps that could be used made by any manufacturer? If I know what kind of clamp I could use I could Google and Ebay for clamps. that used 1.5 inch toolbars so I could search for their clamps.
Usually shimming with an angle will make the toolbar larger. The IHC clamps are 1 3/8 and the bar he wants to use is 1 1/2 so the clamps are too small for the bar.
Can you get some threaded rod. Heat the bend good with a torch and make them? Get some flat stock, cut and drill it to fit. Just a thought.
Make them. Take flat steel and make a "C" that will fit over your shank and reach around the tool bar. Weld a nut in the back side and Use a clamp bolt to hold them tight on the opposite side of the tool bar from the shank.
