1105 massey fergusion
ben brown
have only 1250 psi at remotes running 200 psi on charge pump check at filter out let be four going into cooler and main hyd pump does any one know what charge pump pressure should be i am thinking main pump should be around 2550 psi to 3000 psi
The main system pressure would have been 2250 PSI on a Massey 1105. The higher pressures did not come until the late 1980s and early 90s. Many of today's tractors run 3000 PSI system pressures but the old standard was 2250 PSI from about the early 1960s.
I am not familiar with a MF 1105 at all but it is an open center system. It sounds like the main system relief valve is just set too low or the main pump is shot.
Post this down in the Massey forum and they will tell you pretty quickly what it should be.
its a closed center with a radial pump relief valve is in pump this is one of two 1105 that i work on never given much trouble tried removing relief vale this afternoon it realy not in a good place to get to in bottom hidden by front axle did get bottom plug off but it appears to be threaded in not a lot room and i just had other thing i want to do today so it have to wait tell tomorrow
