Bought this ATV at an auction. It had a car battery on the rear rack with a set of jumper cables connected to the main battery. I had let it sit for about a week and the car battery went dead. Did it go dead because it was connected to a dead battery?
I put a 12 volt clearance light in line with the negative cable. It did not light with the ignition switch off or on, but did light when I turned the lights on. Would this indicate that I do not have an electrical problem, other than needing to replace the main battery?
Thank you
SDE
Thank you
SDE
