Eaton power steering motor
EliG
I have a Case 400 with an Eaton power steering set up on it. It works great but has one problem. The motor is leaking fluid out between the sections. I know there is supposed to be a sealant applied between the sections during asembly but I'm not sure what it is supposed to be.
Any ideas?
Thanks,
Eli
Char-Lynn, (by Eaton) power steering units are
sealed by O-rings, they do not use any type of
goop or gasket sealant. If you can identify the
model, by nameplate, or number stamped into the
unit, seal kits are available.
