timing on GM 1995 350
Anonymous-0
Went to set the timing on my truck and the sticker under the hood is missing with the timing specs. Does anyone have this info available and the proper way to set the timing. I was told that I might have to disconnect a wire beside the distributor. The truck is a 1995 K3500 1ton cab and chassis with a 350 gas auto no A/C
There is a tan wire with a black strip in a single connector. It will either be under the dash near the floor on the right side, or under the black electrical center cover on the passenger side of the bulkhead. Disconnect it and set timing to 0 degrees.
