(quoted from post at 06:46:08 06/03/13) A threshing machine would require a fair amount of power. The reason the longer belts were used was to help eliminate slippage of the belt when the higher power was required. A longer belt, due to it's own weight, will transmit more power than a shorter belt will. A shorter belt is more likely to slip. Mike
