As you can see this is a very large operation, but I just can't complain at how well a match this plow is for this ole 850 ford looks nice in the photo, the job it did. The 110 needed a shin and share, a nice thick rock share went back on, landside was nice, it was a $125 find in '09, shear not trip but... with the top link adjustment and level box adjustment dimensions, written on a 2"x4" scrap, that I took a photo of, easy to set up. Raised the coulter, it has a nice gauge wheel, but I don't use it much, thing pulls nice, hit 2 large rocks, going slow though, leveled up it does not hook up so easily, a root would shear it though, those you can't get past most times.
Also made a badly needed ditch with it today, from a saturated wet spot and or spring, real easy to set pitch with it, water came rolling down right behind it.
The plot above I had to work around a pipe, hence the small un-plowed area.
