johnwayne360
behind a half ton pickup. That is..with no aux brakes of any kind...what would be a safe limit?
And some of it is on 4 lane highway also..(quoted from post at 18:40:44 05/26/13) this particular item is a piece of tillage equipment that weighs close to 6000 lbs. Truck is rated to pull 10k...but without brakes I dont know if im going to risk it.
(quoted from post at 12:31:28 05/26/13) Is the tillage equipment tongue heavy or tongue light? If it's light on the tongue you won't be going very fast but you'll make it as long as you don't have any long downhills. I had a tongue light piece of equipment start swinging the back end on my old Dodge 3/4 ton on gravel. It got so I was looking over the right ditch, then the left ditch, and back and forth until I was at a dead stop sitting crossways in the road. Lesson learned. Jim
(quoted from post at 13:40:44 05/26/13) this particular item is a piece of tillage equipment that weighs close to 6000 lbs. Truck is rated to pull 10k...but without brakes I dont know if im going to risk it.
