Anonymous-0
Anyone here have window air conditioning units in their home? Is there any maintainence that should be done before the hot weather gets here other than cleaning the filter (and removing the outside cover - don't ask)?
All the crud should be removed from the bottom of the case and the coils cleaned. At the minimum carefully use a vacuum with brush on the coils. The best is to use a specific coil cleaner chemical. In between would be to wash them off with a detergent. At my work place (University) I had 2 windows units to keep the equipment cool in the summer months. The UMRs (Utility Maintenance Repair) guy was suppose to cover them for the winter and clean them in the spring, but he/they never covered them and only cleaned them when they were so dirty they stopped working. One summer, out of desperation, I loaded up a spray bottle with detergent and water and proceeded to spray the coils on the dirtier window unit. I had no way to thoroughly rinse out the detergent. When I turned it on there was a flurry of bubbles blowing outside, it was on the 3rd floor. I'm sure you use a similar maintenance procedure on your tractor and combine radiators, don't you?(quoted from post at 16:48:57 05/23/13) Is there any maintainence that should be done before the hot weather gets here?
