farmall a wont stay runnin??
2005
New User
i have a 1946 farmall A that only runs for 5 min. then shuts off..no gunk in sediment bowl..cleaned fuel line to carb..took carb apart cleaned...shined up contact points in dist.cap and rotor..still only runs for 5 maybe 10 min. then off she goes ..it will fire right back up but wont stay runnin??? prob. just started...been a great runner ???? puzzled??? need input!! thanks brian
There may be a screen behind the tube fitting where your gas line connects to the Carb that's full of crud. Hal
I vote for gas cap not venting or the screen in the sediment bowl full of something. just letting enough gas through to run a short time. Something is stopping the fuel flow. first try running without the gas cap off.
As with any gas engine trouble shoot.
#1 make sure you have a good blue white spark that jumps a 1/4 inch gap the moment it dies.
#2 make sure you have a good steady flow of gas out of the carb drain plug for a few minutes. Catch it to look for dirt/water etc.
#3 check the air cleaner and make sure it is clean and has oil not dirt and water in it.
5 minutes to me says gas flow problem be it the gas cap or some junk in the line or filters
