Fuel in crankcase on 1996 CASE=5220 INTERNATIONAL
gitrib
I have a friend who has Case Inernational 1996 model 5220 He Keeps gaining fiud in the Crank Case OIL WE ARE ASSUMING IT IS DESIEL FUEL. i KNOW NOTHING ABOUT CASE. sUGGESTION FROM YOU GUYS, WOUL BE APPRECITATED, SUPPOSE i SHOULD GO TO CASE DISSCUSION BUT YOU ALL KNOW ME. ANY HELP WILL BE APRECCIATED.gitrib (Graydon)
If it has a transfer pump, it could be leaking fuel into the crankcase, or the injector pump seals may be doing the same thing. He needs to find the problem and fix it before he ends up spinning a bearing.
Graydon,
The Case forum is an excellent place to post his question also. Lots of wonderful people and vast amount of Case knowledge to help you there. Best of luck to your friend.
Kow Farmer Kurt
