Needing lists of tractors in the 40s/50s with 50hp
On the Allis Chalmers side you'd have a D17 and D19. A real hard running WD45 would be close to 50. Not sure about the other colors.
AaronSEIA
Can help with the Massey Harris line some.......
A hard running 44 would be just shy of 50hp. The 44 Special and a 444 is right at 50hp. The 55 and 555 are pushing 70hp. Also, all the above tractors are hard lugging four cylinder tractors with great low end torque!
M -M UT series , just a bit over 50HP. M-M "G" series , about 70 plus. Depends how they are set up with compression ratios.
