deerenutz52
New User
Ok I'm reaching out there for any help I can find. I have a 720LP that I aquired and can't seem to get it to run. If I turn the gas on to it let it sit about 5-10 seconds it will putt a couple times then die. I have rebuilt the m-4 converter and it seems to be working properly now and the carb has also been gone over. (actually tried 2 different carbs with the same result) I have found numerous problems incuding the timing being off, a sticking valve, and all have been corrected. It has compression, maybe not the best (about 25-30psi) but i feel it should fire. Currently I have the strainer bypassed and am trying to fire it off of a gas grill tank and the only thing I can figure is that this won't supply enough gas? Any help would be greatly appreciated!!
