sixtyninegmc
Anybody ever seen or setup themselves a truck to pull a NH stackwagon? Snow is still on the ground around here (not normal!), so some scheming is being done. Currently pulling the 4020 off the discbine to pull the stackwagon, which is a pain to change PTO shafts, and the biggest time killer with the pull type is the slow road speed. I`m thinking a medium duty truck can be had much cheaper than another tractor, and I get mirrors wide enough to help back the wagon up to the stack, and controls could be rigged fairly easy in the cab. Think run the PTO with a hydraulic motor, so the PTO shaft could be put back on and run it with a tractor if need be. How crazy am I? A self propelled is on the list, but this would make what I have work a lot better for the time being, my outlying leased fields would be a lot less headache.
