massey engine swap 35 to a 150
62deal
New User
Will a cylinder head from a massey ferguson 150 diesel 3.152 fit on a massey ferguson 35 3.152 ? Both are 3 cylinder engines but the one engine the injecters go in a an angle the other goes in straight,my problem is I swaped engines 35 into a 150 but now the steering drag link from steering box to the front hits the exhaust manifold, any ideas???
Different manifolds on different steering systems is very likely, the 35 was 2 low arms, 150 is a hi bar and post right?.... direct/indirect injection is what you are looking at...different heads/ injectors, may/might need different pistons. You should repost this in the Massey forum on the grey bar above.
(quoted from post at 08:57:54 05/01/13) Will a cylinder head from a massey ferguson 150 diesel 3.152 fit on a massey ferguson 35 3.152 ? Both are 3 cylinder engines but the one engine the injecters go in a an angle the other goes in straight,my problem is I swaped engines 35 into a 150 but now the steering drag link from steering box to the front hits the exhaust manifold, any ideas???
k thanks
The 3-152 is basically 3/4 of the 4-203. The indirect injection 203 has 17 head studs while the direct injection has 23 head studs. I don't know if that applies to the 152.
Different engines. The 35 is indirect injection and
the 150 would have the newer direct injection
engine. There are different exhaust manifolds for
the AD3-152 that may do the trick.
