Another EFI Picture
David G
This is the fuel injector mounted, hosed up and wired on the MH44
David,
really interesting project. What components are you using?? That type of mod could bring some much needed economy to old gassers.
-Paul
Zeb,
It is a project for fun, but I am hoping for better response with less fuel. I will get rid of the carburetor and distributor when done. I can set the timing and fuel curves in the computer.
what EFI system are you using? I've seen retrofit kit's for 2bbl and 4bbl V8's but nothing that would work on a tractor.
The computer is a microsquirt, most of the sensors are delco. I am fabricating the mounting components and generating fuel/timing curves.
I have figured out my throttle body, will fabricate that after timing and injector are working.
