How to get the rear axle nut off on Ford 8N?
sten
Locking clip ring is off but how could I get the required torque to get the 2" nut off without the the 1171 hub and stud assembly turning around?
Thanks in advance
A 3/4"" impact wrench, even a good 1/2" unit, will zip it off in a few seconds.
Last resort: put the wheel back on, let the tractor
down on it block the wheels, set the brake put it in
gear, and get right after it with a long cheater.
Thank you all, I followed Bob's suggestion and off they went, in fact i used a little heat as well.
Thanks
Sten
