bearing race removal
bill mart
Finally have the need to remove a bad bearing race and have been chomping at the bit to try the weld a bead on the race method. What works better , a stick welder or wire or doesnt it make any difference. Thanks, Bill
Makes no difference. The only problem would be if you use less heat with the wire feed. Some of the small ones don't have much power.
thanks to all, my son and I are equally proficient on either machine (me on stick,him on wire.) Bill
I welded a large thich washer to the inside of the race I wanted to remove, thinking I would have something to grab on to. Used a mig. The race just fell out.
son wire welded a few beads this afternoon.couple taps with a punch and its out.Thanks to all. Bill
