Case 26 Backhoe--Can swing cylinders be rebuilt
lenray
Have this old Case 26 Backhoe on the back of a DO MOR tractor.
Can those two hyd. cylinders that are on the bottom that swing the hoe from side to side be rebuilt????????//
thank you
as Loren said yes they can be rebuilt, kits are available from Case, you will need a spanner wrench and a 3/4" drive breaker bar to get the piston rod nut off
