Anonymous-0
I bought a Easyflow running gear a year ago that was froze up where the steering wheels pivot. The steering joint consists of a vertical thick walled tube (which is welded to the running gear). Inside of the tube is the actual axle that goes threw the pipe then makes the 90 degree turn to become the wheel spindle. I have been soaking the joint from the top with PB Blaster where the pipe is open and you can see the inner shaft which is frozen. Wonder if I am going to have to take the wheels off and put some torch heat on it???? What about hammering on the outer pipe?? What about hammering from the top (hate to mushroom the inner shaft). Any ideas about breaking the left and right steering joints loose??? Thanks in advance.
