Electric brakes on a Gooseneck
lenray
I have a 3 axle Gooseneck trailer and have brakes on the front two axles. The rear axle was removed and reworked and reinstalled, but the brakes don't work. Can a guy get the wires miss matched--the hot and the ground or doesn't it matter---any ideas
Thank you
len
Does not matter. Check for power first, then listen, if you have power you can hear the magnets hum. If you get just a little brake first check that they are adjusted. They have to be almost dragging a little. If that's all good then make sure they are on the right side, the are rights and lefts and I've seen more than a few on the wrong side. After that it's time to pull a hub and see what's wrong.
If you are asking about the 2 wires on the electro-magnet, it doesn't matter. There is no power and ground. The electro-magnet is an insulated coil and does not come in contact with the ground of the trailer. So polarity there is not important.
You can connect a battery or charger to the two wires of the brake coil, put a screwdriver in front of the electro-magnet, and you can feel the electro-magnet. It will magnetize your screw driver too.
The back brakes on my 2 axle trailer stopped working. Something had cut one of the wires feeding the back axle.
Get a volt meter and find where the voltage is missing. Try this, pull the safety cable and see if the battery will energize the coils.
