Anonymous-0
I am working on a Ford 250c 3 cylinder diesel tractor. The tractor will run for about 3 minutes with excessive white smoke coming out of the crank case breather tube. The tractor will then stop running. Does anyone have any suggestions on how to correct this problem?
White 'smoke' from the crank case breather could be coolant getting into the crankcase through a hole in a cylinder wall. Check your coolant level and engine oil level and condition! Fixing that requires a complete rebuild with the cylindres being bored out and sleeved.
