OT-2008 polaris ranger 800
4010 puller
Hey Guys:
My 08 polaris ranger 800 isnt running real well. Ive heard they had some fuel pump issues. Mine seemed to have lost a little power in high range and will not idle. If you hold the brake and give it some gas it will run but wont idle. What are some things to look for?
Air leaks around the intake manifold is one off the top of my head .Use an aresol spray and listen for change in rpm. If you crossed a stream then water in bowl. Might want to just drop the bowl and clean it out to check.
