doubletough
I am trying to put a flow divider in pressure line on a Wards tractor to run a char-lyn power steering. The flow divider has 4 ports on it, one port for inlet pressure line, one port for outlet of pressure line that goes on to the hydraulic control valve, a port for the supply line feeding the power steering and I can't figure out the fourth port. Can I just attach the return line from power steering motor to this port or do I need to get it tied into the hydraulic supply tank. I need a schematic of a flow divider to see the the path of oil flow. Where can I get a diagram of a flow divider?
