4010 puller
What is the best way to time a 60gas with engine at TDC? I just had distributor rebuilt and want to get it timed right where distributor needs to be but not sure how to do it.
Can I use a timing light? If so what degree do I use. Ive read 5* ATDC. I also read some where retarded timing is 5* BTDC to 25* BTDC full advance. What is easiest way to set distributor timing and how do you use timing light on these engines?
Thanks
Thanks
