agonair
See several posts about finding items for sale on Craigslist. Is there a way to search the entire database or do you just search at each desired location?
SearchTempest. You enter you zip and select a distance 400,500mi etc and it will search every CL in that mi range
Search tempest is the easiest that I've found so far. I just found a 1000 RPM stub shaft and housing for our Massey 285 on craigslist that I picked up for $25. Normally just the shaft brings over $200, and nobody ever talks about the housing so that was something I never knew was needed until I seen this add.
All told, to buy this new it would probably be closer to $500. (shaft, bearing, housing, snap rings, etc...) Once he replied to my email about it, I called him when I was nearer to him and then drove out and picked it up. Dropped it off at the farm and now gonna put it on some day when it's a little warmer just to check it out.
I REALLY like craigslist... :wink:
Donovan from Wisconsin
