Straw Boss
Talking heads on the news keep talking about gas prices and the soon schedualed switch over in the pipelines from winter gas to summer gas. Whats the difference between the two?
(quoted from post at 17:34:04 02/19/13) The differance is the RVP (Reid Vapor Pressure) of the gas.
Fuels with higher RVP evaporate more easily than those with lower RVP.
Gasoline must have an RVP below 14.7 PSI which is normal atmospheric pressure And this is winter gas.
For summer months the EPA mandates an RVP below 9.0 psi or 7.8 psi depending where you live. Some local goverments have even lower standards.
The reason summer gas cost more than winter gas is they can use more butane in the winter gas. Butane is inexpensive and plentiful but has a RVP of 52 psi
(quoted from post at 12:34:16 02/19/13) Talking heads on the news keep talking about gas prices and the soon schedualed switch over in the pipelines from winter gas to summer gas. Whats the difference between the two?
(quoted from post at 08:02:48 02/20/13)(quoted from post at 12:34:16 02/19/13) Talking heads on the news keep talking about gas prices and the soon schedualed switch over in the pipelines from winter gas to summer gas. Whats the difference between the two?
Once again the old "wife tales" continue. The only thing that happens to gasoline with the summer to winter switch is that the RVP(Reid Vapor Pressure) changes. That means that the vapor pressure (volatility) is increased or decreased by adding more or less butane. I also agree that the market speculators screw up the pricing and that is why we get the price swings..
(quoted from post at 19:15:31 02/21/13) Ken, did you check out the Wikipedia article in my previous post?
"It is defined as the [i:604b74db05]absolute[/i:604b74db05] vapor pressure exerted by a liquid at 100 °F (37.8 °C) as determined by the test method ASTM-D-323."
So vapor pressure is always absolute, NOT gauge. RVP is measured in psiA, not psiG.
