Here is a couple things I have been werking on this winter. I built the fork lift out of a three point hitch fork lift and mounted it on a Power-King garden tractor. It helps to move mowers etc. around the place. I used a remote controlled winch to operate the mast, I ran the cable under the tractor and used pulleys to gear it down and give more lift, it will raise up fur nuff to load in pickup truck.
The udder one is a cut down two seated electric gulf cart that was wore out. I mounted a Cub Cadet tractor to the back of it and moved all the controls in front of seat.The bed is a lawn trailer that I widened and its mounted on tracks to roll back and dump, I let the gravity do the dumping. They aren't done yet as there is some tweeking to do.
