wd45 hand clutch
(quoted from post at 12:20:14 02/12/13) How do I get the shifter out :?: ted r
If you are talking about the trany shifter, there is a pin going thru the shifting tower. Knock is out and lift the shifter out.
You mean the two-piece brass ring in the hand clutch? Don"t think it comes out unless you split the tractor. Did mine when I had the engine out....just pulled next two castings forward. You can also split at the rear and use long guide bolts in the rear axle to maintain alignment. I&T AC 11.
