Dan King 3
New User
Hello I need some help I have a Kubota m120 showing codes on the left side of the dash shows the tractor a line pointing to the middle of the tractor/ with a red gear and a drop in the middle lites up also when I put the tractor in gear the lite that shows the number of what gear your in goes out and a P codes and a buzzer comes on and the tractor will not move forward or reverse Thank you in advance for any help
That symbol on cat loader indicates transmisson oil. I would guess its low, the P would indicate the park brake is on, likely trying to save itself. If the symbol has lines under it, try trans filter. Good luck
On a New Holland it means low hydraulic pressure, I hope you don't have to spend the $17,000 to fix it that I did.
What numbers are showing up there in the codes?
Have a shop manual here will look but I am thinking stopped up hydraulic filter. How many hours on the unit and what kind of fluid in the transmission? How long since the filters were changed? E-mail open
