Negative terminal disconnect
Anonymous-0
If I put a night switch on my negative battery terminal will that
protect from battery drain? It's a normal 12v negative ground
circuit.
Hello,
YES! No power will have a path to the battery.
A cut off is usually installed in series at the plus side.
Guido.
Yes is will stop any drain. Usually it's installed on the Pos cable but which is ever easier to get to is ok too!
Yes in theory it will stop a battery drain if the drain is from something wrong with the tractor or what ever wiring. But if your battery has an internal short or the top is real dirty then it may not help at all. In the long run it would be better to fix the drain then to do any thing else
Always put cut off in grounded side regardless if it is pos or neg. If you open live side you still have possible leak up to the point of where you install the cutoff. Plus, if you touch with tool or drop tool on the battery side of the cutoff you have instant sparks. If vehicle is late model with lot of electronics it is impossible to eleminate some current draw. Theoretically the memory draw of a radio should not draw down a battery in a year or more but when IH started putting solid state radios in the 86 series tractors, batteries were going dead on the lot. Then they started removing the fuse that fed them, problem solved.
my batt are easy accessable, got my 1/2 wrench with me, never use tractors every day, so i just disco the batt, both or power cable.
He was probably referring to AC power distribution, where you shouldnt break the Neutral (Its a GrounDED Conductor) but instead the hot conductor.............
John T
Just call John Brillman 1-888-274-5562.
He sells a really good switch with silver contacts I think.
Put it in the + side.
Every tractor should have one.
Many a barn has burnt down because of a wiring fire on a tractor when nobody was around.
Yes. A battery completes a circuit if positive and negative are connected. If one of them is disconnected, current cannot flow.
For long term storage, manufacturers like Exide suggest charging the battery, and then draining the electrolyte into clean glass, and putting on a shelf. have I ever tried that? Nope. It was just something that came up in an all seminar put on by Exide that I once took on batteries, which is a science all of its own.
But to your point, disconnect one terminal or the other so that it will not complete a circuit, and current cannot flow, so it will not discharge that way.
Mark
The military has used master switches for years. Put it between where it's grounded and the negative battery cable. Here's what the military used. This will isolate the battery from being grounded. If it has battery ignition no one can start it. Hal
(quoted from post at 17:25:44 01/13/13) an electrican told me to never open the ground side.
In residential wiring, you switch the hot wire. The reason is because then you have a "hot" wire at the light bulb, even with the switch off, and you are a path to ground when you go to change the bulb.
On a vehicle, you ALWAYS disconnect the ground from the battery first as a matter of safety. If you go to unhook the hot post while touching the tractor, you get zapped. If you accidentally swing the wrench into a metal part of the tractor with the ground hooked up, you short out the battery. In extreme cases, the wrench can "weld" between the positive post and the tractor's frame. The short circuit can cause the battery to explode in your face.
Not really a good idea in that the starter solonid terminal is easily damaged . If folks are careful it still seems that terminal either turns in the case or gets broken. Works better to do it at the battery and definitely easier if he installed what is pictured in the post.
Hello dependzic,
The fleet at work had the positive side switch from the factory. They were class 8 trucks gasoline delivery fleet.
The switch was intended to be used in case of emergency only. It was mounted on the floor right above the battery box.
Guido.
if this is on a tractor its good but if its a newer car or truck if you unhook the batt the computer looses all its memory and from what i was told its not good for it, i have some "float" chargers i use they are tiny little battery chargers that keep the battery hot and charged they work great and are cheap.
Put a cut off on my Ford Expedition that sits a lot. It was recommended to put it on the negative side.
I have a question, I'm not familiar with the term 'night switch'.
Honest question, just ain't heard it called that.
Maybe I live in a hole, I've called them battery disconnect switches.
Is this a light sensitive switch, hence the name?
Either way, a battery disconnect switch, especially if hidden, also makes a nice anti-theft device, to a certain extent.
Thanks, Danny
I have been in this business 60 years and I can,t see how you say IT IS USUALLY INSTALLED on the positive cable. I have never seen any use from the factor on the positive side. All construction, ie cat, John Deer, Case break the negative cable.
