(quoted from post at 12:28:43 01/07/13) Old, you know better than to say something like that.
ost if not all the 'confusion' could easily been avoided if "grounded" and "grounding" conductor terminology had been avoided like the plague! Of course then it wouldn't have been "code" and a whole industry of classes, books explaining the "code", etc., etc. would not have been necessary. Fortunately, I have my secret Annie Oakley decoder ring, so I can read & understand the "code". What the H would have been wrong with "Neutral" and "Earth"? Just too straight forward? :roll: :evil:(quoted from post at 21:02:11 01/07/13) JohnT, Don't you know all the problems of the world is blamed on teachers and you have tired to teach people something. Keep it up and you will be blamed for all the world's problems.
George
et the 'right' inspector to look at it & he WILL find something 'wrong'!(quoted from post at 10:22:40 01/08/13) I Believe this topic seems to get more response than any tractor question asked. Comes up about every 3 months and has been discussed more than what engine oil to use.. Sure is good reading. I get mixed up in what is a SUB PANNEL .. My Shop is fed 4 wire below the meter But above the house service breaker box. The shop pure ground is also run thru a ground rod there at the shop. Now after that I do have a three wire ran out to the mill shed that is split in to 2 110s . NO GROUND rod so I don,t know if I am in trouble or not. Has worked for 6 years and no shocks so far.
(quoted from post at 12:38:07 01/08/13) On that note I think it is funny how in a common breaker box you have 2 hots coming in at the top and then a neutral bus bar at the bottom and then here is what gets me. The ground and the neutral bot hook to the bus bar at the bottom but call that neutral wire a ground and you get jumped on from both side plus form the top and the bottom but yet electrically speaking they are one in the same if you look at the fact they are hooked to the exact same place but call the neutral ground of ground neutral well you get both barrels
