John Deere roll-o-matic
M Nut
Are all John Deere roll-o-matics the same? I am looking for one that would be the correct fitting for a 530, and just want to know what I should be looking for. Also, does anyone know if Schwartz hubs fit a roll-o-matic spindle? I currently have a schwartz wide front on my tractor, but would like a correct John Deeere narrow front instead. I found a roll-o-matic nearby for $85, but no hubs are with it. Just wondering if it would be a match for my tractor.
Thanks
There are several differences in them. One is the length of the center pedestal, there are longer and shorter ones. Then there are arm and spindle differences too. The early New generations ones had issues with breaking the spindle arms. So they made heavier ones. The heavier ones have a four bolt bearing cap where the light has a three bolt bearing cap.
To really be sure you have the right one you need to check the center pedestal casting number. I don't have that number for a JD 530. I bet that some one over on th JD forum would know it.
If your Schwartz front end is the correct one it very well could have the JD hubs on it. When they where sold new you used the hubs off of your old narrow front on the new Schwartz axle.
