Kow Farmer
Hi there JD Seller,
Just was wondering about how your tractor project is coming along? I believe you posted quite a while ago you had a JD tractor you were going to put together from some other donor tractors. I don't recall the model number it was though. Being a man with your skills and talent, this probably won't go to bad depending on what the issues are that may arise as you rebuild. Just curious. I am always amazed on the mechanical things you write about and are able to fix on so many pieces of equipment. I wish I had just a fraction of that skill/talent. Anyway, best of luck to you on your tractor project. If you could post pictures, that would be cool too.
Thank you. Take care.
Kow Farmer (Kurt)
Kow Farmer (Kurt)
