I'm trying to remove the land and furrow rims on a No 52 plow with enclosed clutch.
The land side - removed cap, pin and collar. The rim slides out, but stops about 1/4 inch before the end. is there something on the clutch side to be removed or disconnected?
The furrow side - removed cap and bolts. The rim slides on the sleeve. The sleeve is not moving - can I heat it up? I'm afraid to use a wheel puller, it might crack the rim.
Thoughts??
Thoughts??
