Could it be that a governor would constantly be chasing itself on an engine with a vaccuum advance as the timing would move every time the governor tried to adjust RPM?(quoted from post at 17:33:01 12/30/12) Why did tractors not have vacuum advance? It seems like that would be an easy solution to back timing off during heavy loads and prevent pinging.
don't believe a word of it. Proof, please!(quoted from post at 21:16:48 12/30/12) Vacuum advance was actually vacuum retard. High vacuum like you would have at idle or whenever throttle was closed actually held the point plate in a neutral or non-advanced state and instantly when you opened throttle and vacuum dropped then it gave advance for acceleration and once rpm was up then centrifugal weights swung out and give it more advance based on rpm instead of vacuum. As a rule , acceleration requires advance and a steady speed engine not so much. Since you aren't usually accelerating and stopping all the time with a tractor like you are a car , you don't need it instantly and you don't need near as much.
