old
- Location
- Camdenton Missouri
Well the other day I came into my office or computer room which ever you want to call it. Any how it is an add on room so has it own heat and cooling. Well any how the room was a lot colder then normal. Checked to make sure the thermostat was turned up like it should have been and it was. Then checked for power and I had the normal 220 volts. I then measured the resistance across the heater and found it top be showing a full open circuit. So does this sound like the old 2nd hand base board heater has seen a better day??
Thanks for any ideas of what to check to be sure
