running carb dry
Rkh
any advantages to shutting off gas supply and letting tractor stall? my concern would be carb sucking sediments from gas see thru sediment bowl.
Rkh,
I have a 1973 Ford 2000, 3 cylinder gas tractor. I use it virtually every day, but I shut off the gas and let it run for about 15 seconds each time I turn it off for the day.
My thought is that I want the needle valve to open a little bit while the engine is stopped.
At the same time, if the needle valve had been stuck open when I stopped the tractor, I don't want the gas to flood out of the carburetor.
Probably just superstition, but it's what I do.
Tom in TN
I always shut off the gas on my gas tractors but after a few days the valve at the tank leaks enough that it refills the carburetor anyway. No worries on sediment. The bowl and screen at the tank should stop everything.
I do this with all gas engines that will not be run in a month or so. I used a chainsaw last week that hadn't been run on THREE YEARS---cranked and ran as it should!
I have had many people tell me that the "gaskets would dry out" LOL---I guess that's why all new gasket sets are soaked in some solution and sealed to prevent drying out ? LOL
Just my opinion and I don't argue the subject!
A carb only sucks air not gas so no problem and as a matter of fact now days it is a good idea to have the carb dry due the the fact this crap gas has alcohol in it which pulls water out of the air and then evaporates and leave the water behind so you end up with water in your carb and that is bad
For 30+ years I've been running the carbs dry ALWAYS. Never had a lick of trouble. And the engines seem to start faster/easier than if fuel is left in the bowl.
No worries of "sucking sediment" from the sediment bowl. Rather it collects/holds any sediment so it WON'T get into the carb.
I also have been doing that with everything but my chainsaws for around 30 years. Used to have gummed up carbs before that and never since.
I have started to do this more lately. Occasionally you have to clean the sediment bowl screen (more often than before), but other than that I've had no issues.
The early 2 cylinder John Deere tractors had no magneto kill switch, so turning off the fuel was the preferred way to stop the engine. It took several seconds to empty the carburetor bowl. With dual-fuel, that prepared the tractor for the next cranking cycle on gasoline. Cranking a cold engine on kerosene is impossible.
Occasionally, if it was still quite hot, both weather and engine, it would crank on kerosene if rolled down a steep hill for speed. Big smoke if it fired up!
I tried that a time or two. Every time I did it the motor died a slow death. Just about the time I thought it would quit it got a shot of fuel again, and made horrible sounds. It is a big motor with 4 in pistons, maybe that's why? Now I just use the kill switch. Stan
talked to my mechanic & he said that the needle valve seal would dry out & doesn"t recommend it.
