Finding shop that rebuilds clutch parts
JOCCO
Trying to find a place that can re-do clutch and pressure plates. Anyone on here have the details. Need it for some of my obsolete items. I herd it was in the mid west. Thanks all
Take all my stuff to unique automative, at jonesburg Mo. A bigger town a little farther east is warrenton, a little bigger, makes jonesburg easier to find.
Can verify that Ky Clutch is a very good place to have work done. Had a combine clutch go out so called before taking it there for repair. They had me out in less than 30 minutes with new buttons on the disc. Will recomend them to anyone. Joe
If your local auto parts store is any good, they'll have connections to someone that can do it. You best bet is likely Napa. They should know someone that can do it.
As suggested Hy Cap in Humboldt IA is a popular shop that does quite a bit of work. I have had good luck with stuff from them.
As far as Clutch and Water pump rebuilds I use Allied Precision in Pocahontas IA. One county west of Hy Cap. Probably the main reason is Poky is only 15 miles from me so it is a easy convienent drive.
jt
Best-Bilt Parts CO Inc
Clutch & Drive Line Rebuilders, Best Bilt Parts Company, Inc
2527 E Kearney Street
Springfield, MO 65803-4968
417) 869-0703
can also try South Bend Clutch in South Bend. They did my Case 730 clutch. Fairly reasonable.
