Clutch adjustment on Farmall 706?
Replaced the clutch in the old 706. Went to the local Dealer and asked how to adjust the clutch. He started rattling off it was a long process and it took several special tools and his tools were long gone. I asked about the TA dump valve the anwser was much the same but he also said it takes a factory trained tech to make the adjustments. What information I did get has me so confused I don't know if he even knows? Can any one explain how to adjust the clutch and dump valve in simple terms! Thanks
Can't help you on the clutch particulars, but my pet peeve is not being able to get a straight forward answer.
Had a real sharp operator that worked for me in my excavating business who was an electrical engineer. Couldn't answer the simplest questions without 10 alternate scenarios. Don't know how many times I said to him: "Daryl, I don't want to know how to build a watch, just want to know what the time is!"
The SPECIAL TOOLS you need is (1) massuren stick , (1 3/4 inch wrench ) , ( 1) 7/16ths open end wrench (1) 7/16ths boxend wrench or socket . Next ya want to make sure that the OIL lite iin the insterment cluster is working , IF not FIX IT .
Now go to the right side of the tractor and unhook the transmission brake after ya loose up the lock nut on the rod.
Next loosen up the lock nuts on the clutch rod and make sure the adjuting nut will turn.
Now go to the dump valve and loosen up the lock nut on it and back the adjusting bolt out about four full turns.
Next adjust the free travel of the clutch pedal to 7/8 to 1 inch massured from the edge of the floor plate to the edge of the clutch pedal at the arrow. And lock down the lock nuts , your done there .
NOW you need and extra foot to hold down the clutch pedal to the stop on the side of the clutch pedal to the floor plate while you hold the transmision brake lever back against the gear and adjust the cleves out so that the pin will slide into the hole in the brake lever , once it SLIDES in then release the clutch pedal and ADD ONE MOVE FULL TURN and replace the pin and hair clip ( now sometimes on linkage that is extreamly wore you may have to ADD a extra half to two more turns to the cleves to get the brake to work correctly )
NOW for the dump valve adjustment , Haave your helper start the tractor with the transmission in Nutral and park loc set then push the clutch pedal down and start to turn in the dump valve adjusting bolt and do this slowly and have your helper tell you the min-second that the oil pressure lite in the dash cluster comes on as soon as it comes on STOP , shut off the engine let the clutch up and ADD ONE MORE FULL TURN TO THE ADJUSTING Bolt AND LOCK DOWN THE LOCK NUT.
You have now completed a clutch adjustment on a 706 . This aslo applys to the 806-1206 and for the 56- 66 series tractors the only difference is the free travel setting on the clutch pedal .
Tractor Vet's post is one of the best I have ever read on adjusting the clutch on an IH clutch. Follow it and you will be good to go.
