Anonymous-0
We have an 4320 (serial number 14319). The hi-low synchronizers are out and the 1st-3rd gear on the lower shaft is bad. Below is a list of parts we need. My research tells me these are the correct numbers. Please correct me if you find a mistake. Can you supply me with price and availability? The numbers in parentheses are quantities, if more than 1 is required. Thank you for your attention.
R92411 Rockshaft cover gasket
R99292 Transmission gasket
JD8291 Rear bearing cup
JD7232 Rear bearing cone
JD8236 Front bearing cup
JD9047 Front bearing cone
RE227962 Synchronizer
R31036 Drum (2)
R63074 Spring (4)
R63075 Ball (4)
R56462 O-ring (3)
R43253 Oil pump gasket
RE20734 PTO brake
R50365 Plate
JD9046 Bearing cone
JD9112 Bearing cup
AR93240 Gear
R26066 Splined coupling
R154778 Bearing cone
JD7430 Bearing cup
AR58191 LH brake line
R31036 Drum (2)
R63074 Spring (4)
R63075 Ball (4)
R56462 O-ring (3)
RE20734 PTO brake
R50365 Plate
JD9046 Bearing cone
JD9112 Bearing cup
AR93240 Gear
JD7430 Bearing cup
